Re: Tomos Biturbo
Joel /
I put a biturbo on my '92 tomos golden bullet ttlx and also put a 53 jet in it. I can go up to 50mph down hill and ~40 on flat ground. The best way to put the pipe on is with vise grips, they adjust with a scew on the side to clamp with vise like strength to a nut. It will take a while since you hafta clamp them on and then rotate the nut a tiny bit and unclamp them, repeat the process.... but you will be having lots of fun after you get that thing on there. I still want to go faster, i'm going to try several different air filters to see if they make th engine perform better..
  Tomos BiturboTopic by: Armando Armando 12/29/00 09:09PM
  Re: Tomos BiturboRe: Tim Tim 12/30/00 01:40AM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 12/30/00 01:49AM
  Re: Tomos BiturboRe: Armando Armando 12/30/00 07:53PM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 12/31/00 10:37AM
  Re: Tomos BiturboRe: Joel Joel 12/31/00 03:29PM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 01/01/01 01:23AM
  Re: Tomos BiturboRe: DOUG D DOUG D 01/01/01 08:26PM
