Re: Tomos Biturbo
Ataristyle /
Very easy to install. All you have to do is loosen up the nuts that attach this Muffler to the engine and loosen up the nut towards the back wheel that holds the Muffler in place. When you put the Turbo muffler on, the only problem you will run into is putting the two nuts onto the studs that connects the muffler to the engine. Since this pipe is bigger, there is alot less room to use a socket. What you will need to do is use one wrench perpendicular and attach another onto it to use to turn it. This will be able to make it nice and tight.
Swarm and Destroy!
  Tomos BiturboTopic by: Armando Armando 12/29/00 09:09PM
  Re: Tomos BiturboRe: Tim Tim 12/30/00 01:40AM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 12/30/00 01:49AM
  Re: Tomos BiturboRe: Armando Armando 12/30/00 07:53PM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 12/31/00 10:37AM
  Re: Tomos BiturboRe: Joel Joel 12/31/00 03:29PM
  Re: Tomos BiturboRe: Ataristyle Ataristyle 01/01/01 01:23AM
  Re: Tomos BiturboRe: DOUG D DOUG D 01/01/01 08:26PM
