Re: Technigas pipe
JunkyardDog /
Even with the stock filter, you will be running lean if you install a performance pipe, and don't rejet. A foam filter will make it even leaner, so you have to rejet richer. But with a foam filter and a pipe, you are getting a lot more air/fuel mixture in and out of your engine. Since you are moving more air, you need a larger jet to keep the A/F ratio the same. 2 strokes are very sensitive to proper air/fuel mixture, that much I do know. A 2 stroke will make the most power when it is right on the edge of being too lean, but I don't like edges, so I'd rather give up 1 or 2 mph, and make sure I don't burn a hole in my piston. It's a genuine Tomos piston. Peace. Jerry.
  Technigas pipeTopic by: Aj Aj 06/13/08 10:04AM
  Re: Technigas pipeRe: the drifter the drifter 06/13/08 10:48AM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/13/08 05:19PM
  Re: Technigas pipeRe: SABAT! andDestroy SABAT! andDestroy 06/13/08 05:33PM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/13/08 05:38PM
  Re: Technigas pipeRe: SABAT! andDestroy SABAT! andDestroy 06/13/08 05:45PM
  Re: Technigas pipeRe: homoped homoped 06/13/08 05:32PM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/13/08 05:46PM
  Re: Technigas pipeRe: Mr. Duncan Mr. Duncan 06/13/08 05:50PM
  Re: Technigas pipeRe: SABAT! andDestroy SABAT! andDestroy 06/13/08 05:52PM
  Re: Technigas pipeRe: homoped homoped 06/13/08 06:02PM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/13/08 06:13PM
  Re: Technigas pipeRe: Eric P Eric P 06/13/08 06:09PM
  Re: Technigas pipeRe: foxboss9 foxboss9 06/13/08 06:12PM
  Re: Technigas pipeRe: wang chung tonite wang chung tonite 06/14/08 04:00AM
  Re: Technigas pipeRe: Homoped Homoped 06/14/08 04:41AM
  Re: Technigas pipeRe: the drifter the drifter 06/14/08 10:49AM
  Re: Technigas pipeRe: Zeke Zeke 06/14/08 11:51AM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/14/08 02:16PM
  Re: Technigas pipeRe: homobile homobile 06/14/08 12:47PM
  Re: Technigas pipeRe: homobile homobile 06/14/08 12:57PM
  Re: Technigas pipeRe: Homoped Homoped 06/14/08 01:58PM
  Re: Technigas pipeRe: Zeke Zeke 06/14/08 03:15PM
  Re: Technigas pipeRe: the drifter the drifter 06/15/08 01:45AM
  Re: Technigas pipeRe: JunkyardDog JunkyardDog 06/15/08 03:59AM
  Re: Technigas pipeRe: the drifter the drifter 06/15/08 09:14PM
  Re: Technigas pipeRe: the drifter the drifter 06/16/08 06:31PM
  Re: Technigas pipeRe: James James 06/16/08 06:38PM
  Re: Technigas pipeRe: James James 06/16/08 06:40PM
  Re: Technigas pipeRe: homoped homoped 06/16/08 08:13PM
  Re: Technigas pipeRe: Mike T Mike T 06/16/08 09:16PM
  Re: Technigas pipeRe: James James 06/16/08 10:34PM
  Re: Technigas pipeRe: the drifter the drifter 06/17/08 12:58PM
  Re: Technigas pipeRe: homoped homoped 06/17/08 01:13PM
  Re: Technigas pipeRe: the drifter the drifter 06/18/08 01:03PM
