Re: PA50 variator installation
Fred /
Wow ... 1 1/2 inches off ???
How does that happen ?
Thats has to be the source of the problem.
Have you taken the flywheel off ?
It sounds like somebody took it off and didn't line something up correctly ?
On the Pa's with points ... there are 3 pins that locate the flywheel to a 'holder' ... I have never had it off.. but the holder must be located with a key on the crankshaft?
maybe the key sheared?
or is missing ?
I am surprised it even runs at 1 1/2 inches off.
You could ship me that stuff to inspect and ship back .. thats fine with me .. but I doubt I would find anything .. its so simple.
I would take off the flywheel and that holder and see what the deal is with the key.
... the one odd thing (from the past)... one of those ramp plate dimensions you listed was quirte a bit different from mine wasn't it ? .. there might be 3 different ramp plates maybe.
reading about other peoples problems .. (with the same bike) .. bugs me .. I want to have it in my hands and fix them.
  PA50 variator installationTopic by: Fred Fred 08/20/02 08:04PM
  Re: PA50 variator installationRe: Fred Fred 08/21/02 03:42PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 03:50PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 05:40PM
  Re: PA50 variator installationRe: Fred Fred 08/21/02 06:03PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 06:06PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 06:37PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 06:59PM
  Re: PA50 variator installationRe: Fred Fred 08/21/02 08:13PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 08:30PM
  Re: PA50 variator installationRe: david f martin david f martin 08/21/02 09:51PM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/21/02 10:04PM
  Re: PA50 variator installationRe: Fred Fred 08/21/02 10:41PM
  Re: PA50 variator installationRe: Doc Holliday Doc Holliday 08/26/02 12:23PM
  Re: PA50 beltRe: Fred Fred 08/26/02 03:01PM
  Re: PA50 variator installationRe: david f martin david f martin 08/21/02 10:08PM
  Re: PA50 variator installationRe: david f martin david f martin 08/21/02 11:00PM
  Re: PA50 variator installationRe: Fred Fred 08/21/02 11:20PM
  Re: PA50 variator installationRe: david f martin david f martin 08/22/02 12:46AM
  Re: PA50 variator installationRe: ItsLookingUp ItsLookingUp 08/26/02 12:34PM
  OEM Belt measurementsRe: ItsLookingUp ItsLookingUp 08/26/02 01:40PM
