Re: rustyyyy gassssss.....
Air Bud /
muriatic acid is powerful stuff, I dont know i'd suggest shaking the gas tank while it's full of the acid. do the handful of washers bit with water or vinegar, then drain and then do the acid and just let it sit for an hour. half and half acid and water mix should be more than strong enough to eat away any rust. You should also be wearing goggles and a respirator (not a dust mask) whenever you're using the acid. to nuetralize spills, use baking soda, then rinse with water once the fizzing stops, don't just swish it away, that shit is poison and you're just washing poison into the ground if you hose a spill off. If you want to nuetralize a whole bucket of waste you're going to need like two of the big boxes of baking soda, and a bucket that's more than twice the volume of the waste, cause it bubbles a lot when it neutralizes. It's way more dangerous, but you can neutralize it easier by putting your respirator gear back on, taking the bucket out to an empty parking lot, and pouring a bottle of ammonia into it. THIS CREATES CHLORINE GAS, WHICH CAN KILL YOU SO DON'T SCREW AROUND IF YOU USE AMMONIA.
  rustyyyy gassssss.....Topic by: robby robby 06/10/08 11:18PM
  Re: rustyyyy gassssss.....Re: SABAT! andDestroy SABAT! andDestroy 06/10/08 11:33PM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/13/08 03:54PM
  Re: rustyyyy gassssss.....Re: Jon Jon 06/11/08 12:34AM
  Re: rustyyyy gassssss.....Re: triumph3434 triumph3434 06/11/08 01:26AM
  Re: rustyyyy gassssss.....Re: SABAT! andDestroy SABAT! andDestroy 06/11/08 01:29AM
  Re: rustyyyy gassssss.....Re: BryAn eurism BryAn eurism 06/11/08 02:11AM
  Re: rustyyyy gassssss.....Re: Andy Andy 06/11/08 03:55AM
  Re: rustyyyy gassssss.....Re: SABAT! andDestroy SABAT! andDestroy 06/11/08 03:59AM
  Re: rustyyyy gassssss.....Re: Zeke Zeke 06/11/08 11:08AM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/11/08 12:32PM
  Re: rustyyyy gassssss.....Re: Kuro Neko Neko Kuro Neko Neko 06/11/08 12:39PM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/11/08 12:43PM
  Re: rustyyyy gassssss.....Re: Kuro Neko Neko Kuro Neko Neko 06/11/08 12:51PM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/11/08 01:06PM
  Re: rustyyyy gassssss.....Re: Kuro Neko Neko Kuro Neko Neko 06/11/08 01:07PM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/11/08 01:08PM
  Re: rustyyyy gassssss.....Re: Kuro Neko Neko Kuro Neko Neko 06/11/08 01:18PM
  Re: rustyyyy gassssss.....Re: RiTZ RiTZ 06/11/08 01:20PM
  eat nails you get rusty gasRe: Doctor Shiftago Doctor Shiftago 06/11/08 01:54PM
  Re: eat nails you get rusty gasRe: robby robby 06/11/08 03:05PM
  Re: rustyyyy gassssss.....Re: michael moore michael moore 06/17/08 01:43PM
  Re: rustyyyy gassssss.....Re: Air Bud Air Bud 06/17/08 02:04PM
