what is the carb setings on a honda pc50
Hey can someone help me i need to no whats the carb setings on a honda pc50..thanks
Re: what is the carb setings on a honda pc50
hey really need some help i dont no what the screws are sepiost to be at??????
Im not sure what you mean by carb settings but if your talkin about the needle valve setting its usually about 2 turns out and work from there, just keep adjusting til it runs and idles good.
carb settings on a Honda PC50
yep .. Jap carbs usually have an idle mixture screw that is set between 1 and 2 turns out from all the way in.
Try 1 1/2 turns out for a start.
If it has another screw .. its probably the idle speed screw .. and it holds the butterfly or the slide open just a little bit,
