Re: a35 tomos trans fluid
midday oil /
check the type F transmission fluid website .. it's made by Ford, and on the website Ford says do not use Type A in newer transmissions where type A is recommended. The A35 is relatively new .. but if you don't want to follow manufacturers' recommendations that's up to you.
