Re: kitted engine oil supplement
elliot in England /
true for real kitted bikes, not ur run of the mill "throw a kit on it" ped^^
when I see a tomos with oil injection hanging with with the real kit tuner 55+ crowd during an entire rally, I will believe in its ability to provide oil for a kitted ped. Till then try not to fall off ur "kitted" tomoses when I blast you.
You know those peds at rallys hitting 60, 65, 70mph and holding it for 10-15miles at a time, going pretty much balls out all weekend rn't using injectors (not even the tomos). They are also the same bikes that don't seize at rallys, win all the races, and go on all the rides even the 80mile ones.
just saying.
they might not be ultimately as reliable as a stock tomos but they are damn fucking reliable for what they are: 400% increase in power, and an upjet of over 60 steps. Oil injectors on a bike like that are just one more variable that can send a $600 setup into the trash...
if your going for a mild increase in speed then sure trust the injector it will probably work great for you, many mild tunes and stock bikes can run at 60 or 70:1 if its a good synthetic so don't sweat it. But if your planning for some real power from your setup, ditch the injector. there are more important things to worry about, and minimizing variables in the setup is very important. the bikes mentioned above also run 32:1 ratios generally.
  kitted engine oil supplementTopic by: midday oil midday oil 06/10/08 09:43AM
  Re: kitted engine oil supplementRe: Terry Horlick Terry Horlick 06/10/08 10:53AM
  Re: kitted engine oil supplementRe: Moped Jay Moped Jay 06/10/08 12:46PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:52PM
  Re: kitted engine oil supplementRe: Andy Andy 06/10/08 11:00AM
  Re: kitted engine oil supplementRe: corey corey 06/10/08 11:13AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:55PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/10/08 11:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 01:00PM
  Re: kitted engine oil supplementRe: Matt Smith Matt Smith 06/10/08 01:11PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/10/08 01:35PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:46PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:56PM
  Re: kitted engine oil supplementRe: Zeke Zeke 06/10/08 03:28PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 07:47PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 04:28PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 08:02PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/11/08 12:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:24PM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 12:48AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:28PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 03:23AM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 03:54AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:30PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/11/08 01:12PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/11/08 02:36PM
  Re: kitted engine oil supplementRe: Zachary Evans Zachary Evans 06/11/08 02:12PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 02:53PM
