Re: kitted engine oil supplement
elliot in England /
basically in the case mentioned above what if any would be the advantage to using the oil injector at all.
I'd think to get a more accurate mix one would pre mix the whole amount of oil and ditch the injector, since using jet sizes to calculate how much fuel is entering your motor is not ever going to be as accurate.
Bypassing the injector altogether would be safer, easier and less work cuz you know in one step if the oil ratio is correct, you don't need to calculate anything nor do you have to fill the oil reservoir any more. By just adding the oil pre carb in the gas so it can be properly metered by the main jet if more efficient and more accurate on a kitted bike.
  kitted engine oil supplementTopic by: midday oil midday oil 06/10/08 09:43AM
  Re: kitted engine oil supplementRe: Terry Horlick Terry Horlick 06/10/08 10:53AM
  Re: kitted engine oil supplementRe: Moped Jay Moped Jay 06/10/08 12:46PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:52PM
  Re: kitted engine oil supplementRe: Andy Andy 06/10/08 11:00AM
  Re: kitted engine oil supplementRe: corey corey 06/10/08 11:13AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:55PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/10/08 11:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 01:00PM
  Re: kitted engine oil supplementRe: Matt Smith Matt Smith 06/10/08 01:11PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/10/08 01:35PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:46PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:56PM
  Re: kitted engine oil supplementRe: Zeke Zeke 06/10/08 03:28PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 07:47PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 04:28PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 08:02PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/11/08 12:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:24PM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 12:48AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:28PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 03:23AM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 03:54AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:30PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/11/08 01:12PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/11/08 02:36PM
  Re: kitted engine oil supplementRe: Zachary Evans Zachary Evans 06/11/08 02:12PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 02:53PM
