Re: kitted engine oil supplement
elliot in England /
ok ii am going to entertain this injector idea with my moped knowledge (i'm seriously curious not trying to cause shit) lets say I need to upjet 15 jet sizes from stock to properly jet for my new kit (be it 50cc or 80cc whatever) pipe and larger carb. the motor now makes more power and revs higher, the percentage is unknown (how you anyone figure that out anyways aside from a dyno.)
how does the oil injector recalibrate for this new situation? if i understand it correctly, it gives a specific dose at every revolution that was predetermined to be 50:1 at the stock jet size in the stock carb.
So if I upjet 15 sizes then the amount of oil in each dose will no longer be adequate correct. or am i missing something? In that case you either need to add oil to the gas at some ratio thats pretty much undeterminable or bypass the injector all together to obtain an accurate oil to gas ratio.
is this wrong i have no experience with oil injectors? something tells me that if the oil is added after the carb thus its not metered by the main jet it will always be at the wrong ratio if that main jet is changed since more fuel is blasting out the jet than the oil dose was designed for.
  kitted engine oil supplementTopic by: midday oil midday oil 06/10/08 09:43AM
  Re: kitted engine oil supplementRe: Terry Horlick Terry Horlick 06/10/08 10:53AM
  Re: kitted engine oil supplementRe: Moped Jay Moped Jay 06/10/08 12:46PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:52PM
  Re: kitted engine oil supplementRe: Andy Andy 06/10/08 11:00AM
  Re: kitted engine oil supplementRe: corey corey 06/10/08 11:13AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:55PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/10/08 11:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 01:00PM
  Re: kitted engine oil supplementRe: Matt Smith Matt Smith 06/10/08 01:11PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/10/08 01:35PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:46PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:56PM
  Re: kitted engine oil supplementRe: Zeke Zeke 06/10/08 03:28PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 07:47PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 04:28PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 08:02PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/11/08 12:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:24PM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 12:48AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:28PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 03:23AM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 03:54AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:30PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/11/08 01:12PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/11/08 02:36PM
  Re: kitted engine oil supplementRe: Zachary Evans Zachary Evans 06/11/08 02:12PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 02:53PM
