Re: kitted engine oil supplement
midday oil /
Terry - if your engine gains it's extra power in cubes per inch (if you've oversized your rings or piston) then that sucks in more gas, but an oil injector works on RPM, injecting no more oil than when your enjine was smaller cubes, so you need extra oil to regain the 50:1 ratio called for. But you are also right in that if your extra horsepower is coming from higher rpm with no increase in cubes, you don't need to add any more oil as the injector will also be turning at higher rpms. I suppose, though, that if an injector is electronically controlled, if there are injectors like that, it would have to be modified or oil added to the gas.
  kitted engine oil supplementTopic by: midday oil midday oil 06/10/08 09:43AM
  Re: kitted engine oil supplementRe: Terry Horlick Terry Horlick 06/10/08 10:53AM
  Re: kitted engine oil supplementRe: Moped Jay Moped Jay 06/10/08 12:46PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:52PM
  Re: kitted engine oil supplementRe: Andy Andy 06/10/08 11:00AM
  Re: kitted engine oil supplementRe: corey corey 06/10/08 11:13AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 12:55PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/10/08 11:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 01:00PM
  Re: kitted engine oil supplementRe: Matt Smith Matt Smith 06/10/08 01:11PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/10/08 01:35PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:46PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 02:56PM
  Re: kitted engine oil supplementRe: Zeke Zeke 06/10/08 03:28PM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/10/08 07:47PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 04:28PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/10/08 08:02PM
  Re: kitted engine oil supplementRe: Edward Richardson Edward Richardson 06/11/08 12:19AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:24PM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 12:48AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:28PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 03:23AM
  Re: kitted engine oil supplementRe: SABAT! andDestroy SABAT! andDestroy 06/11/08 03:54AM
  Re: kitted engine oil supplementRe: midday oil midday oil 06/11/08 12:30PM
  Re: kitted engine oil supplementRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/11/08 01:12PM
  Re: kitted engine oil supplementRe: elliot in England elliot in England 06/11/08 02:36PM
  Re: kitted engine oil supplementRe: Zachary Evans Zachary Evans 06/11/08 02:12PM
  Re: kitted engine oil supplementRe: James G James G 06/11/08 02:53PM
