Re: 2 stroke with 10 pistons? (Fred?!)
Interresting side note: Any ped with a decompressor has A valve. When you pull the lever this valve opens up a passageway between the head and the base of the motor thus allowing combustion gases to return to the crank case from where they cometh' to reduce the pressure in the combustion chamber to make the engine easier to turn over.
