I put in a 1/3 extra rich oil mix in my 1983 and now the thing won't fire up at all. I've drained and replaced the fuel and changed the spark plug. Help.
Have you checked for spark?
Check to see if spark plug is wet (wet probably means to much oil in the mix.) or fouled bad, if it is you will need a new one. I usually go 50:1 or 2.6 oz to one gallon of gas.
if that's not it you might have blew a tailight bulb somehow.
I did check for spark and it was yellow. should it be some other color?
blue
