Re: What do you think about this?
Small step up from a 14-12. Price is OK though.
Just make sure you can get small enough jets for it. Some replicas don't use real dellorto jets.
i think you better cross your fingers and hope that dellorto jets will work in a 'replica' carb.
chinse knock off can you find jets for it? do delorto jets fit it?
but what the hell for $20.00 can't lose maybe
wow 3 people with the jet thing in 60 sec
screw jets! for $20, buy a set of microdrills like me and drill the jet out! if the jet is pressed in, make sure to pull the needle and clean the shavings out!
Matt Scout The Scouting Dcon /
I've tried that carb. Decent construction for a clone, but just buy a used 14.14 if you are worried about cost. For the time you would spend in either modding this carb to use genuine Dellorto jets or making your own using microdrills, you are honestly better off.
anyone have a used delorto? my other question is will the 14.14 hook up directly to my bendy intake?
Re: out come of a knock off Carb
Sure buy the cheap ass carb that use made at gun point. I prefer the pay for the real thing.
please note a small problem with the cheap ass carb
<object width="425" height="344"><param name="movie" value="
&hl=en"></param><embed src="
&hl=en" type="application/x-shockwave-flash" width="425" height="344"></embed></object>
make mine well done
Want to reply to this thread?
