is this normal?
is this from casting ?is it cracked? is it gonna leak?
Re: is this normal?
it happens a lot, 90% you are fine. old metal =(
Re: is this normal?
That looks like casting leftovers to me. E50 cases have them on the bottom usually, they look like cracks but they're convex.
Re: is this normal?
yep, normal and from casting. you can use dye to tell if its a real crack.
Re: is this normal?
toe fur threadkiller /
i freaked the first time i saw this on an E50. then i was told it was from flaws in the casting, and no big deal. then i just never thought about again.
here's to you not having cracked cases when you thought you did.
raises beer in salutation
Want to reply to this thread?
