Re: My allstate compact ALIVE!!!
axman /
well i found the switch, it up under the kick starter connected to the rear brake lever by spring. time to figure that out, i did talk to motor west and he has them on the shelf, if the switch is bad.
another question, how to you lub the cables and what should be used.
thanks for the help
