Re: Best way to start a 50v?
keller_stephen /
I start mine on the stand, use the decomp, the one on the right handlebar, pull it in if you have to give a bit of throttle and pedal away! be careful not to let the spinning rear wheel hit the ground for obvious reasons..if these reasons are not obvious pedal start it on its wheels. Best of luck and have fun! I never use the choke on my moby it seems to "upset" the carb causing stumbles etc, it starts and runs sweet with out it.
