Carb?
My bike doesnt run at stops, i want more power, is the best solution a new carb? where can i buy one online in the USA?
Re: Carb?
Clean that carb. Your idle jet is probably clogged...
Re: Carb?
its doesnt start very easy either, probably has something to do with it as well huh?
Re: Carb?
Its a dellorto sha carb right? Should be super easy to clean out. Make sure to clean out all the little holes well, expecially the one under the slide. Thats the one that controls the idle.
Re: Carb?
i dont know the carb model, i think its stock, 50v motobecane.
Re: Carb?
Oh, Gurtner carburetor then. Either way, it'll be much cheaper to take it apart and clean it rather than buy a new one.
Re: Carb?
how can i beef it up to go faster? its pretty slow, maybe 20 on flat ground, i dont have alot to spend, would a different pipe make it alot faster? what kind of pipe should i get, where should i buy
