Removing rust from pulleys and such and protecting
Hi guys, I need to remove some rust from my pulleys and my plantery gearbox on the rear wheel. Once I remove it, how can I protect the pulley and the gearbox from rusting again?
Re: Removing rust from pulleys and such and protec
Cleats Onionpockets /
Get it completely free of rust, including what could be in the little pockmarks, and clear coat the thing. That'll keep the bits that don't get rubbed against free of rust. The bits that do get rubbed against should be fine as long as they are used, as the friction will help keep the rust from building up
Vova Fett /
ven OP
Thanks! Can I also spray the parts with a fine layer of epoxy?
sure
