How do you attach the slide on a Tomos?
So I was trying to clean my carb....long story short, I can't figure out how to put the slide back on the throttle cable. Do I have to thread it through the spring first? Also what holds the cable in place? Pictures would be greatly welcomed.
Kuro Neko Neko
Re: How do you attach the slide on a Tomos?
Heres how I run mine.
Kuro Neko Neko /
So does the slide fit into the grove at the top or what...mine does not stay. Can you retake the first picture and show how the slide holds.
Kuro Neko Neko
Kuro Neko Neko /
Le bump
Kuro Neko Neko
I just slide the lead cable end into the cut out in the slide, and it holds in there pretty well. You can see that the opening is wide and then the slot on the top narrows to hold the cable
I run my wire through the spring
Kuro Neko Neko /
Thanks Saabsonettguy, the second picture helps. Captin poop, thats not the same carb, I've already looked at that video.
Kuro Neko Neko
