fabing manifold
so i went down to lowes today and found the perfect iron pipe to fab my manifold from. for those of you who don't know i am in dire need of a 17mm bing manifold. so i have started cutting a flange that the pipe screws into down to for on my engine. after that i am going to start chopping the pipe down, weld everything together and slap that bad boy on. So far everything is a perfect fit, thank god. i was going to take pics of the process, but i forgot to. so i will start them up now.
Re: fabing manifold
I.R.E. Mike Pee /
Once you make that one, make 10 more. There's a market here fo' sho'.
Props for fabbing your own stuff man.
Re: fabing manifold
Aaron(Zeo) /
i might toss all the work i am doing out the window and go buy a miter saw. it would be so much easier then dremeling it. if it works i will make a couple and put them up on the buy sell. lol its going to use alot of jb weld though.
Re: fabing manifold
could one just open up a 15mm just a tad with a drill press?
Re: fabing manifold
Aaron(Zeo) /
would it bolt on though?
Re: fabing manifold
Bruce Edwards /
I fabricated a custom intake from tubing I cut off of an abandoned shopping cart. The picture doesn't show it but it's even chromed.
