TOMOS: What motor should I use??
I have a 78 tomos bullet and I'm trying to decide between rebuilding the original motor with a 70 cc speed kit or maybe just converting to the new LX or sprint motor. Any opinions??
Re: TOMOS: What motor should I use??
Hell, convert AND go 70cc. If you're gonna go for speed, go all the way dammit ;-)
very good point. maybe that'll be the way I go.
chuck russo va /
u cant even put a kit on a A3 motor, they ahve 10 mm wrist pin and the kits use a 12mm
so only a35 motors work on the kits, but they have the same bolt patter so its a perfect match
classic tomos with hopped up moden motor would be sweet
<daydreams thinking of Tomos frame and CR125 engine>
<wipes drool off chin>
chuck--
I called mopedwarehouse and Athena does have a 60cc and a 70cc kit for the A3 motor. They are not in stock though so they can't be viewed on the webpage. MW said that the kits are identical to the A35 kits except for the wrist pin as you mentioned.
