Re: Discovered why I was slow as Kzoo
Mark Ryan /
yeah there is a lot you can do to a stock cylinder first.
some people put playdo in the crankcase with the cylinder off or cooled wax- to prevent metal shavings from going off into the engine and dremel it down to match the cylinder-(just remember to remove the playdough afterwards! (the advantage of cooled wax is once you clean teh metal shavings off the wax acts as a lubricant so it can just stay in there-- you can also widen the transfer ramps on both case and cylinder. you can also cut the piston skirt by a few millimeters, lower the intake window, raise the exhaust port window by 1-2mm. i recommend the minarelli 15mm intake on a puch because they easily fit 15 and 16 dellortos and clear the engine easily. but you have a bing, nevermind. you can also shave down your cylinder head. anyway, all of this is easy to do- just be careful because a mistake can sometime fuck up yr cylinder. it is good to have a spare puch cylinder to do this to so if you fuck up you aren't screwed. anyway. there are a lot of posts in the performance section probably about this and im sure some portwizards could chime in here. anyway- 40's are definately doable on stock cylinders.
  Discovered why I was slow as KzooTopic by: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 04:05PM
  Discovered why I was slow as KzooRe: brystheguy brystheguy 06/02/08 04:09PM
  Re: Discovered why I was slow as KzooRe: joe schuit joe schuit 06/02/08 04:10PM
  Re: Discovered why I was slow as KzooRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 06/02/08 04:11PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 04:15PM
  Re: Discovered why I was slow as KzooRe: Mark Ryan Mark Ryan 06/02/08 04:19PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 04:29PM
  Re: Discovered why I was slow as KzooRe: Roberto Roberto 06/02/08 04:33PM
  Re: Discovered why I was slow as KzooRe: Mark Ryan Mark Ryan 06/02/08 04:34PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 04:44PM
  Re: Discovered why I was slow as KzooRe: Mark Ryan Mark Ryan 06/02/08 04:54PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 05:02PM
  Re: Discovered why I was slow as KzooRe: N Wesley N Wesley 06/02/08 05:24PM
  Re: Discovered why I was slow as KzooRe: Mark Ryan Mark Ryan 06/02/08 05:39PM
  Re: Discovered why I was slow as KzooRe: fish_SHARK fish_SHARK 06/02/08 05:52PM
  Re: Discovered why I was slow as KzooRe: [[ Linda ]] [[ Linda ]] 06/02/08 06:09PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 06:15PM
  Re: Discovered why I was slow as KzooRe: Mark Ryan Mark Ryan 06/02/08 06:28PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 08:53PM
  Re: Discovered why I was slow as KzooRe: MadtownMick MadtownMick 06/02/08 11:16PM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/02/08 11:32PM
  Re: Discovered why I was slow as KzooRe: Dave Brzezicki Dave Brzezicki 06/03/08 12:35AM
  Re: Discovered why I was slow as KzooRe: Bitter Bitter 06/03/08 12:47AM
  Re: Discovered why I was slow as KzooRe: I.R.E. Mike Pee I.R.E. Mike Pee 06/03/08 12:53AM
  Re: Discovered why I was slow as KzooRe: Nash . Nash . 06/03/08 12:54AM
