So for months I have been pounding away on my Tomos to figure out why when I kicked it over it was running WOT throttle ever time since I put on my Airsal kit. I had all brand new gaskets and new carb. I thought maybe my intake wasnt tight enough causing an air leak, or something. I used the old carb cleaner spray trick and discovered it was coming from there. So I took the engine apart, tightened the bolts like heck, then put it back together. Still the same problem. I tried it again and this time put copper gasket sealer on the gaskets. Still nothing. So finally about after the fifth time of taking the engine apart, I'm thinking my new gaskets were bad, I took another new one and when I put it on I noticed that the gasket overlaped the reeds just slightly. So I trimmed it accordingly and what do you know it stopped the WOT condition.
But it was still running a little high on idle, so then I did the carb cleaner trick again and realized i was missing that little rubber thing on the inside of the carb where it attaches to the intake. And on today, on this day of days, I got it running finally, and I took it out for a ride even as it started pouring rain, and it was the best feeling in the world even though it hurt. And it made me realize how much I truly love mopeds.
