Re: technigas worth it or not?
Saabsonettguy . /
I don't have any experience with the tecnigas but I have the estoril which is similar in design and performance. I think you'll like it, it should have a wide powerband and I think their built fairly well. One word of advice though, keep an eye on the rear exhaust bracket. It should be ok as long as you don't go hitting any curbs but if it does break off the frame have it welded/reinforced immediately. Without the rear frame exhaust mount the pipe can be damaged and it can put stress on the manifold studs.
