Re: How do you take Restricters(governers) off a P
Nelson /
Ok...this is what you do...open up the wheel as if you were changing the brakes. There should be a circular plate in there...Mine is a PA-50..it has two plates(one on each side).<br>After findin the plate take it off and make holes in it. There is a tool you can get to make this(i got mine from Colemans Motor Sports). Do this to the from and back wheel. Becareful the back wheel is trickier. <br>Good luck and dont F*ck up your Moped.<p>
  How do you take governers off a PA50?Topic by: Jason Jason 05/29/99 09:30PM
  Re: How do you take Restricters(governers) off a PRe: Nelson Nelson 06/01/99 02:59PM
