Re: 1977 Sparta Buddy
Ro_Man /
You can either dissasemble it and clean it bit by bit with a can of carb cleaner or get a bucket of parts cleaner (a 1 gallon bucket, aout $20) and let it soak. Make certain that the float moves freely and is seated properly. Check the tip of the float needle , make sure the rubber tip is still on it and in good enough shape to seal off the flow of gas.
What's the carb brand and type?
