I was told I could run ATF (auto trans fluid) in my wet clutches instead of 20wt., what do you guys think?
model, yr of moped make ?
alfons74@hotmail.com
It's an 1981 General 5 Star with a Minarelli engine, where I ride there is alot of hills so I need some good "grabbing" power out of the clutch. I'm a big guy (200 lbs.)so I'm trying to get the most out of the bike. On level ground, it's fine, I thought the clutch plate might be worn out, but when I checked it, it was ok. I probably just need more power, by the way, my other bike is a 1340cc Harley.It has NO problem with hills.
