i need a diagram for a peugeot ignition, because the wires on mine are all torn apart. i have a batavus that is of the same year. the igniotions look to be the same. i was thinking i might just try to wire it the same way my batavus is wired.
peugeot ignition diagram
Re: peugeot ignition diagram
What model/year peugeot? i have a 103sp which i also had wires disconnected and hanging out before i fixed them. which wires are all torn apart? are the wires under the flywheel all ok? there should be two wires coming out of a single grommet, one purpleish and thicker and one red (i think those are the colors). Another grommet should have a black wire coming out. and yet another grommet should have the spark plug wire coming out.
the wires that re gone are the ones under the flywheel
Yes that definately will need to be fixed before you'll get spark. Are the two coils there? there should be one with fine strands and a spark plug wire coming out of it (is this missing too?) and another with heavier gauge wire. There should also be a condenser and breaker points in there. If these are missing, you'll have to find a place to buy replacement parts.
Sportsbay.com has Peugeot manuals. If all you need is the diagram I could scan the one I've got. I'll check back here.
i would like ur diagram
i have the coils, and points and all that. All i need is to know is where the wires for the points and coils connect to.
what are names of the Peugeot manuals on Sportsbay.com?
