Re: OT; just got a 60s Evinrude 4hp Lightwin
Chris P /
Oh theres nothing to be fixed. Motor doesnt smoke, starts right up, runs smooth (when the mixture is proper), and even idles real low. Had it out on the water today for like 3 hours, and it was running for most of that time, and it was at WOT for a lot of the time. Mounted on a 13ft row boat...its all the motor that thing needs.
I suppose maybe changing the gaskets would be a good idea, there is a little oil around the outside, though Im pretty sure that could just be coming out the carb. Other than that Im under the impression I should make sure the impeller (water pump) is working properly, even though it showed no signs of running hot.
If the consensus is I should stick with the stock carb, well cool then, its kinda neat. But I definitely think I should have twin expansion pipes... Again, only to lessen the amount of fuel going into the water.
So any ideas what displacement this is? Or even if you knew the displacement on your 3hp that would give me a general idea. id like to know what size the carb is on your 3hp too, again, just so I know a bit more about this thing.
  OT; just got a 60s Evinrude 4hp LightwinTopic by: Chris P Chris P 05/25/08 11:41PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: ~ DeeZy ~ DeeZy 05/26/08 12:12AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: ~ DeeZy ~ DeeZy 05/26/08 12:14AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 01:22AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:03AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 01:25AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Saabsonettguy . Saabsonettguy . 05/26/08 01:12AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 01:33AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:53AM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 12:06PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: skywriter skywriter 05/26/08 01:20PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 01:37PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:32PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 01:49PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:49PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 02:04PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:54PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 01:56PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 02:08PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: salient salient 05/26/08 04:25PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: andrewhed andrewhed 05/26/08 05:44PM
  Re: OT; just got a 60s Evinrude 4hp LightwinRe: Chris P Chris P 05/26/08 07:57PM
  OT; just got a 60s Evinrude 4hp LightwinRe: UtOh UtOh 06/21/08 05:45AM
