tool names and sizes...
I need to fix a couple of things on my magnum...
both tires
new gas lines
test electrical system
I just need to know what kind of tool(s) I will need to change the tires with. It would be helpful if I had a specific brand name and or tool size (if applicable.) Also, what size tubes and tires does a Magnum take anyway?
THANKS IN ADVANCE
Kuro Neko Neko
Re: tool names and sizes...
Thanks...is this the only thing I need? Ugg, being a noob sucks..thats why I'm fiddling with things to see how things work.
Kuro Neko neko
tire irons any kind really to take of your tires
an electrical tester resistance thing for seeing if u have a circuit. then the closest volts above what u r suppose to have to check what kinda volts u have actually and if your battery is dead.
fuel line should be 5/16 fuel line (i would take some of yours in and ask if they have any and what size it is) your local motorbike shop should have some
fuel line should be 3/16 not 5/16 thats on a car :p
tires and tubes are 17x2.25-2.50 (your choice) tubes that are bigger than your tire are generally fine.
if youre getting gasline, 3/16" and get a fuel filter too.
tire irons are cheap on jc whitneys site too.
This is _so_ not what I thought this thread was gonna be about.
(Little Elvis, btw)
I assume Elvis the name and little is the size?
Want to reply to this thread?
