1980 tomos A3 magneto question
which brand of flywheel (CEV,Ducati, ZEM, ISKRA,IDM) came stock on a tomos a3.
i have an ducati right now and when i put the stator to where it needs to be for the correct spark only one of the mounting screws line up. and when i but it to where the mounting holes line up the spark happens at the bottom of the stroke, not the top as it should be.
i was thinking of replacing the whole stet up with the correct one , but if anyone can help me make this one work that would be great
thanks in advance!
Re: 1980 tomos A3 magneto question
Your bike probably came with a Ducati. Install the 3 screws loosely in the stator plate and then the plate should have maybe 1/4" of side to side adjustment when twisting it. http://www.mopedriders.com/html/manuals/tomos/auto3/tomosauto3wmp40.jpg
yeah but when it's attached where it's supposed to be it's 180 out m and it doesn't run
bunp
I have an 80 bullet and it came stock with a ducati. as for the rest of your problem I can't help, sorry
are your points on the right or the left side?
bump
Want to reply to this thread?
