1970 suzuki 50
i have a 1970 suzuki 50 and it bogs down when i give it gas then picks up, i moved the pin up one notch to see if that would do the trick, should i move it down or is that not the problem.
and also it has two cables coming off the throttle one goes to the throttle then another goes to the injector where would i set the screw, it tightens and loosens the cable. what oil should i put in the tranny
