fuel tap
On my fz50 there is a tap for the fuel. It has three position: pri, res and on
I guess on means open and res means the reserve. But what is pri?
BTW: If it is in the pri position, the carburator leaks gasolin.
Re: fuel tap
Prime? Like for priming the carb with gas for cold starting?
Re: fuel tap
isn't the choke used for that
fuel tap
The Prime is used to bypass the vacuum activated petcock so if the bowl is empty you can fill it in this position. When I have left mine on Prime, it seems to use more gasoline as opposed to the other way.
Re: fuel tap
well it seems you may be right. When left with the valve on PRI the
Want to reply to this thread?
