Source for 44mm (1.5mm thick) GI-type rings
Are their any brands with bigbore sized rings of this type? My kit needs new rings but is obsolete, I can't find a replacement.
Re: Source for 44mm (1.5mm thick) GI-type rings
what brand is your kit, what make and model is it for? I can look into it.
Oh? It's an Autisa Sachs/Hercules kit 65cc's from Spain. Thanks for the help.
you mean the 62cc Autisa kit?
I happen to have a few piston kits for those
Is your's is stock and hasn't been tampered with, it should be a 43mm bore. I have NOS piston kits for the 43mm, 43.5mm and 44mm.
This is a goldmine!!! How much would you want for a NOS 43mm piston kit? I can just reuse the old cylinder with a little crosshatch work eh? No I haven't tampered with anything at all...the cylinder has a few fine lines from some soft-seizing though.
bump
email me, chad at quarterkick.com
baBUMP, you have email Chad.
it was chad@quarterkick.com yeah? need that piston kit or at least some rings asap my dude the compression is 135psi down from 170psi
Want to reply to this thread?
