easy fix?
so this guy claims it is not running but "an easy fix"
http://slo.craigslist.org/bik/679883007.html
What should I look for when I go and look at it to tell if it actually would be?
what are some signs its going to be a bitch?
also can anyone tell what model moped it is from the crappy pic?
Thanx
Re: easy fix?
Ah, another Sachs! Looks like a Columbia Commuter, ( basically a Westlake with different side covers). Sachs is pretty easy to work on and most parts are available. It would be a good reliable bike once it's fixed. If it turns over it will likely be an easy fix. The carbs are a "square" Bing and pretty basic. The ignition comes in to varieties: Motoplat, and Bosch. The Bosch system is simple and nearly identical to puch. I've never dealt with the Motoplat but I hear they are a lot more difficult. Still, I can't see it being that bad to work on and there is a good knowledge base here. The only down side is that there is not a great variety of performance parts available. It will be a great daily rider but probably not a speed machine unless you want to spend big $$$.
Re: easy fix?
