Re: No keys
Curly T /
Yep, the key is for the front fork lock only. It is easy for anyone to break anyway so I drilled mine out when the key got lost also. You will have an almost impossible time finding a blank for a locksmith to make a new one, so instead just drill it out and use the money you'd give to the locksmith to get a really good cable lock.
-Curly
(Someday you may find a used lock & key set and it is easy to install if you save the original retaining clip)
