Throttle Adjustment and rambling
1991 TOMOS TT-LX GOLDENBULLET /
Hi,
attached is a photo of the throttle.
It doesn't return/spring back when you release it.
Its sort of a cruise control feature.
But, I would like to repair it.
I've tried to use a screwdriver and a few drops of 3-in-1 oil to move the exposed spring? that is visible in the photo.
But, I have no idea which way to move it.
In general, without taking it apart and making a mess of it, can I fix it?
Also, replaced the spark plug with a Bosch B5HS, only .99 a the local auto parts store, cheapest of the bunch, and my TOMOS has been running great!
Also, read the posts about the bi-turbo muffler.
Bought this moped last month and it has a bi-turbo on it.
Since I never rode it with a stock muffler I have nothing to compare it too.
Easily attains 30 - 35 mph speed.
Will upgrade to the $22, 27 tooth front sprocket eventually.
Regards
Wanted! Atleast 1 reply
Does anyone have an answer to this question?
Re: Throttle Adjustment and rambling
> can I fix it?
I see no 'exposed spring' ... I have worked on Tomo's throttles (a little bit) and I don't remember any 'exposed spring'.
So I don't know what you are talking about .. or how you would 'move it'.
(but I could be wrong about a spring there)
Can you fix without taking it apart ?
I dunno ... have you had your magic wand tuned up lately ?
Will you make a mess of it ?
Sorry ... I am fresh out of "seeing into the future" visions.
.. maybe contact Madame Cleo for a 'reading' ??
You usually have to take things apart to fix'em.
..and it more than likely needs a new throttle cable installed.
(which is a pain in the A$$ for an experienced mechanic .. a rookie with little mechanical aptitude might just commit suicide during the attempt)
Oh, you remembered !
Reeperette /
You think Fred's normally cranky, ya shoulda seen him tryin to reset the throttle of the Blue Rocket that day.
It's a bitch royale to adjust it, or put a new cable in them things - was I you, I'd take a very small screwdriver, and...well...ok.
| | }0
| | }00000000
| | }00000000
| | }0
I know, a pretty awful Ascii, but still....that second "line"...where the metal piece is kinda slipped out of the plastic throttle cover ?
Try prying that back away from the rest of the handlebar assembly, or perhaps loosen the assembly and move it a bit, cause it's probably rubbing, which is why it catches like that.
I'd also hit that spot with a little graphite, for good measure.
Worth a try, at least...but if the cables kinked, yer outta luck.
-R
did another one
actually ... I installed a new throttle cable on the Tomos of the kid who sold you yours ... a week ago .. thats why its fresh in my mind.
The designers of the things could have made it soooo much simpler ... if they had tried to.
