Help with lubrication for 1-speed MAXI
Do I have to lube the crankcase on a 1-speed PUCH motor? I've got a 2-speed, but my friend has a 1-speed. He flipped his crankcase/motor upsidedown and a bunch of red oil came out through a small 1/4" port. Is that where we should add ATF or something???
Re: Help with lubrication for 1-speed MAXI
The red stuff is the same stuff you have in your 2 sp Puch 9.5oz.
1 spd just takes less,5 3/4 oz. or up to the filler hole which is the screw on your clutch cover.Type F transmission fluild. Dan
