Starting my MAXI on the centerstand is impossible
I can't get my MAXI started on the centerstand...there is way too much compression when I pull the lever and my pedals stop in less than 1/2 a turn. What's the trick??
Re: Starting my MAXI on the centerstand is impossi
Quit pulling the brake lever.if the compressions that good you should be able to climb any mountain in Pa.
Try starting with the pedal a little bit turned already. From a straight up and down position it can be hard sometimes -- try with it slightly forward already. If properly tuned it will start on a half kick of the pedal like that.
simon
I always run start my Puch. Pull in the clutch lever, run a few steps, and jump on.
same here, i took the pedals off mine, i just get on, push myself forward a bit, pull the lever and it starts right up.
Trac Man
wow, my bike is a bear to start. I gotta get a tune-up
