Re: Top speed and questions
[[ Linda ]] /
Yes, you probably want to check the jetting in your carb. You will likely need a larger jet than what you've got. What size do you need? We can't say. There's no magic formula that will give you the jet size you need. Figure out what you've got in there already, and buy a range of sizes that are larger than what you've got. Start with the biggest one and work your way down to smaller jets, doing plug chops with each jet change until your spark plug looks good. If you run a search for this info in the performance tuning section, you'll find enough reading material to keep you busy for the next month. There's good stuff there, you just have to look. (Also read the wiki on performance tuning if you haven't already.)
