A performance exhaust is more for top end speed than low end power. If you have speed approaching the hill you will power up it better, however if you are at a dead stop prior to the hill you will not see a lot of difference. If you are unhappy with the performance (at any range) of your ped, I would highly recommend a performance exhaust system. It's the most boost for the money you can do to improve the ped.
