help me i really need it
flannelman /
i got an 88 razz and it bogs down when i ride it
it started at first only at high rpms
now it does it all the time any time i give it gas
cleaned the carb already i cant get this one and i need help
Razz bogs out
Its either
.. not enough fuel flow to carb
.. clogged carb
.. clogged exhaust pipe or exhaust port
.. low compression from worn out or damaged rings or cylinder
.. leaking head gasket
.. YOU .. have to be the detective
Re: help me i really need it
clean the air filter recently?
