fuel leaking from encarnwi carburator on Tomos A3
Fred-Indiana /
Anyone know what causes fuel to leak from the carburator on a 1985 Tomos A3 - Encarnwi carburator?
I checked the float and it is installed correctly? Does it need replacing?
Does the jet need replacing?
Fred
Re: fuel leaking from encarnwi carburator on Tomos
Reeperette /
I posted a reply to your original.
Lemme repeat it here, then.
Take the carb out, remove the float, which is upside-down.
The pointy end of the metal bar through the plastic float should point UP, not down.
So simply remove the float, turn it rightside up, and put it back in.
Problem solved.
-R
