RE: Bore kit+Tomos= Broken Tomos
Reeperette /
Awww, crap....I didn't think to ask, but was this an A5 Targa Engine or an A3 "Alpha" Bullet engine ?
Cause this sounds like the reason WHY you don't drop that upgrade kit on an A3 Engine set, the A3 Pistonarm assembly is slightly different in size from the A5 Pistonarm assembly, and this can, and will, cause major problems eventually.
Still, as Ron says, it may not be terminal, but you will need a salvage A5 Trans, to hook it up to, in order to get it running right.
-Ree
  Bore kit+Tomos= Broken TomosTopic by: Tim Tim 12/12/00 05:58PM
  RE: Bore kit+Tomos= Broken TomosRe: Ron Brown Ron Brown 12/12/00 07:40PM
  RE: Bore kit+Tomos= Broken TomosRe: Reeperette Reeperette 12/13/00 09:56AM
  RE: Bore kit+Tomos= Broken TomosRe: Tim Tim 12/13/00 07:07PM
  RE: Bore kit+Tomos= Broken TomosRe: Ivo Ivo 12/13/00 09:09PM
