Re: More info....
Fred /
Don't worry about timing for now .. removing the head and cylinder will have no effect on timing.
GET A NEW SPARK PLUG .. get a couple .. run the W&D sandpaper thru the points and clean them again.
Thats probably all it needs.
.. one of those electrical splice connectors should work fine for now .. (though I always try to solder any ignition connection like that .. as a more permanent reliable fix)
  Help me....Motobecane engine saga continues...Topic by: Larry Larry 08/04/02 12:28AM
  Re: Help me....Motobecane engine saga continues...Re: david f martin david f martin 08/04/02 12:50AM
  More info....Re: Larry Larry 08/04/02 10:12AM
  Re: More info....Re: Fred Fred 08/04/02 10:47AM
  Re: More info....Re: Larry Larry 08/04/02 10:52AM
  Re: More info....Re: Fred Fred 08/04/02 11:05AM
  Re: More info....Re: david f martin david f martin 08/04/02 01:27PM
