oil mix
I just bought a 1981 Garelli. What is the oil gas mix? It says 1.0gal (gas) to 3 pull (oil) What is a pull?
Re: oil mix
Joseph Grimes /
The pulls are for the Oil Injector tube on the side of the tank. Guess yours is missing?
I never use the Injector anyway on mine. I always premix the oil and gas. My 1980 Garelli manual says 3 3/4 oz of oil per gallon of gas.
2 stroke oil in the gas, non-detergent motor oil in the crankcase.
Re: oil mix
Thanks. I will try the 3 3/4 oz. to one gallon.
Re: oil mix
You can try this mix. After a little while take your spark plug out, if you think it is too wet. Try 50:1 or 2.6oz per gallon of gas. This mix is standard for me so far.
Re: oil mix
Thank you.
