1978 Garelli (oil injection)
rick /
I have a 1978 Garelli moped with oil injection. It never has run right. It would never idle correctly. it stayed running when i floored it and I didn't stop to let it idle. it would stop running after about a day of little use. Until I get a new spark plug, then it would run for another day of short use... I did that repeatedly. I thought it was the carburetur, so I bought a new one, and a new air cleaner. but no help. I remembered that it was oil injection....that might be the problem. I pumped a little oil in it a day (two pumps or so), I think it needs a correct mixture, how much? does anyone know how much the mixture should be? I could mix the gas and oil instead of pumping the oil in the tank
Does anyone know where I can get rings for it also?
  1978 Garelli (oil injection)Topic by: rick rick 08/02/02 02:24PM
  Re: 1978 Garelli (oil injection)Re: Wal Wal 08/02/02 05:25PM
  Re: 1978 Garelli (oil injection)Re: neilo neilo 08/02/02 09:00PM
  Re: 1978 Garelli (oil injection)Re: david f martin david f martin 08/02/02 11:05PM
