Re: Oil Pump-Is it working?
tabpat /
The only way I know of is to fill the tank with pre-mix and disconnect the line going to the intake. Plug the hole in the intake. Run the line to a small cup and check for flow. If you want to check for correct volume, you have to have the worshop book on the engine and it will give the specs as how much should flow within a certain amount of time..
