Re: Oil Pump-Is it working?
Reeperette /
Those little clamps that hold the lines on ?
There's leakage there, even if they're tight they have a problem with being tight on one side, loose on the other.
If you can fit the tip close enough, try using the crimper on an automotive electrical tool.
-R
